Soundcraft VI 4.7 Update draussen
  • MH 3
  • 25. September 2012 um 14:40
  • MH 3
    Ein paar Infos zu dem Thema...sicherlich auch für User interessant! Nicht nur Besitzer.
    The following new functionality is included in Version 4.7:
    • 96-Mix for Vi4! Vi4 Inputs-to-Mix capacity is now upgraded from 72 to 96 (with 3 DSP cards fitted to Local Rack; if 2 DSP cards then upgrade is from 48 to 64)
    • Vi4 consoles now save and load identical Show files to Vi6.
    • Virtual Vi1 Offline Editor now available within Virtual Vi
    • User Interface Enhancements on all Vi consoles:
    * New EQ Units control allows width in 'Q' or Octaves
    * New Delay Units control shows delay time in ms, metres or ft & inches
    * New scroll encoders in Show list
    * New Sort button in Show list allows alphabetical or date-wise list sorting
    * New warning highlight on channel strip when Oscillator enabled
    * ‘Global Pre/post’ button renamed to 'Set Pre/post' (Vi1 only)
    * INV button in Noise Gate renamed to 'DUCK'
    Note re ViSi Remote
    Please note that the current release of ViSi Remote (V1.1.2) only controls up to 72 channels on a Vi4. A new version of ViSi Remote (V1.1.8) is currently awaiting approval in the App Store which will allow control of all 96 channels on an updated Vi4. This is expected to be available for download within the next two weeks, we will announce this when it happens.
    Bug Fixes
    The following console bugs are addressed by this update:
    • Time/date stamp of Show file was not updated when saving show
    • Manual IP addresses in 192.168.1.xxx subnet could not be selected for HiQnet port
    • Using a wireless router with IP address in 192.168.1.xxx subnet on the HiQnet port could stop connection to DSP core
    • Console could restart when HiQnet connection unplugged
    • Error messages generated when starting console up
    The Virtual Vi Offline Editor software is also upgraded with the above bug fixes.
    We strongly recommend that you keep your console up to date and install this new release as soon as possible!
    Show File Compatibility Warning
    Because of the upgrade of Vi4 mixing capacity, and to follow the market demand for better compatibility with Vi6, the layout of the channels within the fixed layers on Vi4 has changed. This means that input channels that were vertically paired in a Vi4 show made on the pre-4.7 software will be split apart and not be vertically aligned any more when this show is loaded on a V4.7 console. This means some work will be needed to reorganise channel layouts where vertical pairs have been used. This would have to be repeated for each snapshot, if individual snapshots exist within the show. Likewise if a show that was made on the new software is loaded onto a pre-4.7 Vi4 console, the same issue will occur, but in this case the recommended solution is to update the console to V4.7.
    This issue is identical to the issue that used to exist when shows were transferred between a Vi4 and a Vi6, except that it will affect Vi4 users with their own shows made on the older software.
    With horizontally paired channels, there is only the minor inconvenience that the pairing between the two channels will be removed when an old show is loaded on a 4.7 desk, in this case the pairing simply needs to be re-engaged and the show saved again. Snapshots will not be affected.
    In the case of Vi1, 2 or 6 Shows, there will be no compatibility issues with shows saved on earlier versions of the software. Show File Compatibility Warning
    Marcus
    • 26. September 2012 um 14:02
    lustig, vor zwei wochen hatte ich genau das als verbesserungswunsch geschrieben ;)
    so löblich dieses update auch ist, da gibt es aber immer noch ein paar hardwareknöpfe ohne funktion... 8)
    darüber haben wir ja in einem anderen thread fleissig diskutiert, schön das es die hersteller genauso sehen!
  • bemi
    • 26. September 2012 um 14:30
    was ich mir in diesem Fall aber genau überlegen werde, da die alten Vi4 Files nicht mehr 1:1 kompatibel sind, da sich die Kanalbelegung verschiebt und vertikale Paare verloren gehen
    • 26. September 2012 um 17:10
    im Verleih wird dir da aber wohl keine Wahl bleiben... ;)
    kein Pairing vs. nicht lesbares File, da dürfte letzteres das schlimmere Übel darstellen.
    Das andere ist halt 5min Copy/Paste und Patching-Handarbeit.
  • MH 3
    • 26. September 2012 um 17:30
    Ich werde mir ein paar neue Defaults basteln und mal ordentlich aufräumen... :wink:
    Vertikale Verlinkung benutze ich aber grundsätzlich nicht, von daher entfällt das schon mal.
    Sehe ich auch, seit der Einführung der Userlayer, nur wenig Sinn drin.
    Mir fehlen übrigens noch frames/ sample beim Delay...
    G MH
    Marcus
  • simonstpauli
    • 26. September 2012 um 19:36
    Kennt hier jemand jemanden, der die vertikale Pair-Funktion genutzt hat?
    Ich finde es sehr gut, daß Soundcraft dieses Problem gelöst hat, auch wenn jetzt einige Alt-Files mit teilweise erhöhtem Aufwand angepasst werden müssen.
  • oton
    • 26. September 2012 um 21:46
    ich habe sie benutzt .. :D
    allerdings habe ich schon als die Custom Layer eingeführt wurden meine Files umgebaut, so das es da keinen Stress geben sollt.
    schön ist das VI6 und VI4 Files jetzt WIRKLICH identisch sind, ich hatte da ein paar dumme Bugs.
    Jetzt noch Dynamic EQ´s und unterschiedliche Abgriffpunkte für die Auxe und alles wird gut ... :wink:
    http://www.popakademie.de
    http://www.otonmusic.de
    http://www.event-akademie.de
  • bemi
    • 26. September 2012 um 23:09
    ich weiss, dass mein wichtigster Kunde auch vertikal gepaired hat ...
    meine eigenen files sind auch alle horizontal gepaired und dann auf user-Ebenen customized. Natürlich kommt bei mir auch das Update aber erst nach Rücksprache. Und hoffentlich ist das Pult welches ich für nächste zumiete noch alt, da ich vom Tour-FOHler ein Vi4 File bekomme (er hat aber wohl auch ein Vi6 File - immerhin ist das für die Zukunft dann gelöst und die Pflege zweier Files obsolet; somit war/ist das auch der richtig gewählte Weg von Soundcraft)
  • thieloliver
    • 26. September 2012 um 23:22
    ...und die Möglichkeit die Customlayerbelegung szenenweise speichern zu können, ONLINE Editoren, die Möglichkeit Eingangskanäle auf die Outputlayer zu legen (imho unerlässlich für Vi2 und Vi1), relative Cues in der Szenenspeicherung, Expander in der Dynamiksektion, Sidechains in den Compressoren, das virtual surround panning aus den vistas *träum*, Remotebatterientausch über die VM2 Funktion bei AKG-Funken :D ...
    Und für Wolfgang alle Knöppe mit Funktion :wink:
    • 27. September 2012 um 01:41
    warum nur für mich, braucht ihr das als besitzer der pulte denn nicht?
    ok, verstehe... "man hat sich dran gewöhnt" :D
  • wikinger
    • 27. September 2012 um 04:28
    Sorry für OT.
    Ein bisschen schmunzeln muss ich jetzt doch! mein billiges iLive hat viel von den geforderten Dingen die ich mittlerweile extrem zu schätzen gelernt habe und mir meistens fehlen wenn ich an anderen Konsolen stehe! ;)
    können Sie nicht ein bisschen leiser machen...???
  • tufkaklto
    • 27. September 2012 um 06:32
    Eh klar, die Ilive Jünger wieder mal.
    Kann natürlich alles besser, daran haben wir uns schon gewohnt.
    Wird das jetzt der neue I Live Tread??
  • tufkaklto
  • oton
    • 27. September 2012 um 09:28
    +1
    Sidechains wäre nett, wenn auch nicht umbedingt mein Hauptanliegen. Bei dem Panning stimme ich dir aber 100% zu, Laufzeitpanning wäre wirklich ein Traum, VOR ALLEM für Live. Komisch das da noch niemand auf dem Zettel hat, egal welcher Hersteller. Wenn ich mir allerdings den DSP-Hunger des Virtuellen Pannings an unserer Vista 5 ansehe verstehe ich es dann doch wieder ... :D
    Ich mache das übrigens inzwischen mit Stereogruppen, in denen eine Seite leicht verzögert ist ... die meisten Digitalpulte haben ja inzwischen genug davon, um ein paar für "Spezialaufgaben" zu opfern.
    OT: nicht streiten die Herren. Das A&H und Yamaha, was Software & Updates angeht wirklich vorbildlich sind, ist wohl einfach ein Fakt. Fanboys hin Fanboys her ... Digico gibt imho viel zuwenig Informationen raus und braucht viel zu lange, um Bugs zu beheben. Und Soundcraft empfinde ich auch als relativ "zäh", das dauert alles doch sehr lange.
  • MH 3
    • 27. September 2012 um 10:00
    Mir würd VistaMix schon reichen :D
    http://www.studer.ch/products/vistamix.aspx?pid=63
    Marcus
  • der diak
    • 14. Dezember 2012 um 19:06
    ...und es gibt gar keine Möglichkeit sich die pipselige Darstellung der EQ- Kurven in den Inputkanälen grösser anzeigen zu lassen?
    ...suck my Kick & kiss my Bass !!!
  • simonstpauli
    • 15. Dezember 2012 um 01:08
    Ich glaube, das geht mit der Fielmann-App. ;)
    • 15. Dezember 2012 um 08:09
    Du meinst die Zeiss App. Das Produkt heißt Lupenbrille. :D
  • gert
    • 15. Dezember 2012 um 16:43
    Also ich mische ja mit meinen Ohren :?
    Practice, Practice, Practice
  • der diak
    • 15. Dezember 2012 um 17:32
    Sehr löblich, ich hingegen lasse mir von meinen Augen gern bestätigen was meine Öhrchen so hören... :o
