Von den IPv4 IPs 104.18.18.121 und 104.18.19.121 kommen die richtigen Files. IPv6 kann ich nicht testen .
Die IPs sind wohl nicht direkt der Server. Bei geht es immer noch nicht. Und es kommt von einer der IPs.
Neues Benutzerkonto erstellenVon den IPv4 IPs 104.18.18.121 und 104.18.19.121 kommen die richtigen Files. IPv6 kann ich nicht testen .
Status 304 sagt, keine Änderung. Du hast die Datei gecached.
host cdn.mediavalet.com
cdn.mediavalet.com has address 104.18.19.121
cdn.mediavalet.com has address 104.18.18.121
cdn.mediavalet.com has IPv6 address 2606:4700::6812:1379
cdn.mediavalet.com has IPv6 address 2606:4700::6812:1279
wget https://cdn.mediavalet.com/aunsw/musictri….1-20251107.zip
--2026-02-11 09:44:50-- https://cdn.mediavalet.com/aunsw/musictri….1-20251107.zip
Resolving cdn.mediavalet.com (cdn.mediavalet.com)... 104.18.19.121, 104.18.18.121, 2606:4700::6812:1279, ...
Connecting to cdn.mediavalet.com (cdn.mediavalet.com)|104.18.19.121|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 34114150 (33M) [application/zip]
Saving to: ‘wing-rack-release-3.1-20251107.zip.1’
wing-rack-release-3.1-20251107.zip.1 100%[=======================================================================================>] 32.53M 87.6MB/s in 0.4s
--2026-02-11 10:01:39-- https://cdn.mediavalet.com/aunsw/musictri….1-20251107.zip
Resolving cdn.mediavalet.com (cdn.mediavalet.com)... 104.18.18.121, 104.18.19.121, 2606:4700::6812:1279, ...
Connecting to cdn.mediavalet.com (cdn.mediavalet.com)|104.18.18.121|:443... connected.
Saving to: ‘wing-rack-release-3.1-20251107.zip.2’
wing-rack-release-3.1-20251107.zip.2 100%[=======================================================================================>] 32.53M 67.6MB/s in 0.5s
Bei mir geht das nicht.
--2026-02-11 11:23:49-- https://cdn.mediavalet.com/aunsw/musictri….1-20251107.zip
Auflösen des Hostnamens cdn.mediavalet.com (cdn.mediavalet.com) … 104.18.18.121, 104.18.19.121, 2606:4700::6812:1279, ...
Verbindungsaufbau zu cdn.mediavalet.com (cdn.mediavalet.com)|104.18.18.121|:443 … verbunden.
HTTP-Anforderung gesendet, auf Antwort wird gewartet … 200 OK
Erneuter Versuch.
Aber egal, habe den Cache nochmals gelöscht. Es bleibt dabei, es werden nur knapp 11MB übertragen.
Jetzt habe ich ausnahmsweise auch mal eine Frage:
Beim umrouten von Kanälen zu anderen Sources möchte man ggf. gerne dass die neue source den gain der alten source übernimmt. Das tut sie in der Standard Prozedur wie beim X32 erst mal nicht.
Eigentlich war mir das bisher in meinen Anwendungen immer egal, weil ich beim SC eh neu gaine.
Jetzt habe ich ein Projekt, bei dem ich massiv sources umrouten muss aber mit den alten gains starten will/muss. Also Aufgabe “copy source gain” .
Über partial load klappt es nicht, weil auch da die gain Information an conn(ection) also die source gekoppelt ist und die gain Information im Kanal sonst nicht hinterlegt ist.
Euer Workaround und bitte keine “könnte vielleicht” Vorschläge.
Ich habe dir leider keinen Vorschlag. Bin aber ebenfalls sehr an einer Lösung interessiert.
Mir würde mal spontan einfallen: OSC Dokumentation lesen und kleines Script basteln. Gains der Sources vorher auslesen, zwischenspeichern und dann zurückschreiben sobald der Patch passiert ist.
Das wäre sicher eine Möglichkeit. Aber das sollte der Gerät oder der passende Editor eigentlich mitbringen.
Könnte das helfen? Habs leider nicht getestet.. https://drive.google.com/file/d/1eYsERV…?usp=drive_link
Könntest du bitte noch etwas mehr dazu schreiben, bevor du einen anonymen googledrive-Link mit einer gezippten .exe-Datei mit kryptischer Bezeichnung teilst?
bzw. auch gleich lieber die Originalquelle angeben
z.B. diese hier: Google-Site von Patrick-Gilles Maillot mit div. Wing-Tools
Von dieser
https://www.behringer.com/product.html?modelCode=0603-AEN
Produktseite aus klappt es bei mir sofort.
Scheint ein flüchtiges Problem zu sein.
Hast du es auch mal mit der Rack Firmware 3.1 versucht?
Dein Link geht ja auf die Fullsize.
Bei mir kommt immer noch die kaputte Datei.
Da sind ja coole Sachen dabei, auch für das X/M32.
Danke!
Hab ich gerade gemacht:
Ja, Download geht, unzippen nicht! Habe es erneut gemeldet.
Bei Patrick-Gilles habe ich schon gesucht aber nichts Passendes gefunden. Der andere super engagierte Seniorkollege Paul Vannatto hatte für X32 mal was geschrieben um die gains zu restaurieren aber der ist für Wing nicht aktiv.
Habe Antwort vom Entwickler-Team erhalten. Es wird gerade versucht, das 'Rack FW3.1 Datei Problem' über Löschen und neu Hochladen zu lösen.
Genau, die Datei kann man downloaden. Aber sie hat nur ein drittel der normalen Größe und sie lässt sich nicht auspacken.
vllt. kann dir tucks irgendwie weiterhelfen
...jetzt hat's mich auch interessiert.
Auf der von guma verlinkten Seite (Behringer Wing) gehen die Downloads und das entpacken von FW 3.1 für sowohl Wing, als auch Compact - beide Files ca. 33 MB groß.
Edit:
Dateinamen:
wing-compact-release-3.1-20251107.zip
wing-fullsize-release-3.1-20251107.zip
edit2:
...sind ja auch schon 3 Monate Alt die Teile ![]()
Hat jemand eine Info wann endlich die Madi Karte kommt? Da ist doch schon vor Ewigkeiten mal ein Bild von einem Prototypen irgendwo rumgegangen auf Facebook. Seitdem nichts mehr gehört.
Hi Miteinander
Achtung, Themenwechsel (ich denk, den FW-Salat habt ihr nun geklärt
Was haltet ihr von dem Vorschlag Richtung MusicTribe die Blätter-Tasten der Compact auch als echte
Layer nutzen zu können?
Beim letzten Festival sah es bei mir noch so aus, dass ich, der Gleitsichtbrille geschuldet neben den Tasten
nochmal markiert hatte
mittlerweile habe ich Busse, DCAs, Matrizen, Main etc. für "mich logischer"
um geschoben, zT sogar doppelt, je nach Layer.
... hab gerade kein aktuelles Bild, aber ich arbeite derzeit gerne in 4 Haupt-Layern,
die ihre DCAs direkt beinhalten, z.T auch Busse, dann ein dediziertes DCA - Bus Layer.
FXe auf den User I / II Matrizen und Main.
Also, blättern mag ich nicht ( bringt meinen inneren Monk dazu, sich mit dem inneren Kinski zu fetzen
Ich finde, das man in DiGiCo-Manier mit der kleinen echt große Dinge zu Stande bekommt ![]()
Wie fein währe es doch, die letzten beiden Tasten der Compact auch für Layer nutzen zu können?
