Ich habe mir erlaubt, da einen Auszug aus einem Rider reinzustellen, den ich persönlich für richtig gut halte.
Ich finde, da ist gut erklärt und gut geschrieben, um was es geht, das sollte jeder verstehen, der eine PA für sowas liefert.
ZitatAlles anzeigenFOH P.A MUST BE CAPABLE OF PRODUCING MINIMUM 120DB AT THE FRONT OF HOUSE MIX
POSITION WITHOUT ANY DISTORTION ACROSS ALL FREQUENCIES. IF THIS IS NOT POSSIBLE THERE
WILL BE NO SHOW.
Ben Frost’s music, at points, relies heavily on extreme dynamics, use of powerful subsonic shifts and blasts of
high frequency. His music is extremely dynamic which makes a modern PA (D&B, Meyer, Nexo, TurboSound)
capable of producing, accurately bass frequencies down to at least 30Hz and highs up to 20k at 120dB without
any audible distortion mandatory. If these technical specifications are not met, equipment can (and will) be
damaged. If the PA is not capable of reproducing 30hz through to 20kHz with the required headroom, then it is
to be assumed that the equipment will be damaged. Running the PA at 120dB is not the goal, but rather
ensuring accurate reproduction of the required frequencies and physicality of the sound without any risk of
distortion or system damage because of large transient peaks or dynamic sections.
...and
