Behringer WING
  • Wurst Werner
  • 17. November 2019 um 18:08
    • 23. November 2025 um 11:21
    • #3.461
    Die haben eine feste Farbe
    Die hand Auflagen machen Leute selbst.
  • joefi
    • 27. November 2025 um 13:08
    • #3.462
    Firmware 3.1 ist online
    .... Die Kunst, das Ziel zu erreichen ist: es nie aus den Augen zu lassen .... 8)
    • 27. November 2025 um 14:20
    • #3.463
    Behringer WING Firmware Update
    Version 3.1 (7 November 2025 )
    Added
    • WING-DANTE expansion card can be used with AoIP -WSG module (use the following
    string for module registration: CRD -WDWSG). Check the “Behringer AoIP (Dante and
    WSG) module relocation instructions ” document
    • New compressor plugins: Even 88 -COMP, LMT Compressor, One Knob Compressor
    • New dual-band dynamic EQ plugin available in the Gate and Compressor slot
    • Expanded noise gate and compressor selection available on Aux channels
    • Direct inputs to Phones and Speakers monitoring buses
    • Multiple Sources can be selected on the SOURCES screen by touch and drag. Parameter
    changes are applied to all selected Sources
    • Preamp gain and phantom power accessible on the User Patches screen
    • INIT/COPY toolbox includes Bus to Bus and Bus/Main to Matrix feeds
    • Insert effects reset button without changing the processor model
    • Setup > Surface > Fader/Screen Layer Link switch enables the main display and fader
    layer to show different channels
    • Faster access to Custom Controls configuration screen by pressing the SETUP button
    twice
    • WING COMPACT: Main Fader can be assigned to all channels
    • WING COMPACT: new “ Keep Main Fader” option
    • WING COMPACT: DCA spill mode can be activated by pressing the SELECT button on the
    desired DCA
    • USB 4-Track Recorder destination folder can be changed (REC PATH button)
    • Return to the previous screen when a Custom Control assigned to a Fader or Overview
    screen is pressed a second time
    • Bus Feed Configuration screen allows copying channel fader levels to sends levels
    Changed
    • All dynamic processors are available in both the Gate and Compressor slots
    • Ducker plugin: increased HOLD time to 4000 ms
    • Gate and Ducker plugins: added infinite RANGE
    musictribe.com behringer.com• Optimized Channel/Source colors for TFT displays and expanded color selection
    • Increased maximum remote client number from 16 to 24. Make sure your network
    bandwidth supports this.
    • Added channel names to Bus Feed Configuration screen
    • Improved dynamics’ crossover filters and visualization. Shaded area is compressed.
    • Added notch filter to dynamics’ sidechains
    • Added option to stop SD recording when an error pop -up shows up
    • Console initialization now overwrites parameters selected in the Global Safe screen
    • Moved ALT Source switch from CONN to I N content category in the snapshot scope
    • Auto Rider plugin: maximum HOLD time now shown correctly as “INF”
    • Improved parameter resolution on some plugin parameters
    • Graphic fixes on Pulsar EQ, Fortissimo 110 EQ and Source Extractor
    • Firmware file name for WING/WING BK renamed to “wing-fullsize”
    Fixed
    • Tape Machine plugin frequency response
    • NoStressor plugin introducing unwanted distortion at certain parameter combinations
    • USB audio interface playback stopped after errors often caused by electrostatic
    discharges
    • Sporadic issues with the USB audio interface at 44.1 kHz sample rate
    • Graphic EQ fader selection using cursor buttons (WING/WING BK)
    • Shimmer Reverb and Stereo Flanger: reset button
    • CC channel solo button follows exclusive solo setting
    • Wrong MIDI port #2 name string for WING Rack and Compact
    • User Patch polarity ignored under specific conditions
    • User Patch not following the mute status of the assigned Source
    • 27. November 2025 um 14:41
    • #3.464
    ...DAS klingt irgendwie nach "Ups ! stimmt ja ! Da liegen ja noch Leitungen rum ! Laßt uns die mal benutzen !"
    • 27. November 2025 um 14:53
    • #3.465
    Wie geil ist das denn? Ich freue mich. Ein kleiner Gamechanger!
    • 27. November 2025 um 14:54
    • #3.466
    Hat schonmal jemand den Rotary-Speaker EFX benutzt? Wie ist der?
  • duplobaustein
    • 27. November 2025 um 14:55
    • #3.467
    Sehr feines Update! 👍
    music is the best - Zappa
  • Herr Nink
    • 27. November 2025 um 15:02
    • #3.468
    Jo - allmählich wird´s Zeit das ich auch mal ´ne Wing unter die Finger bekomme...
  • Circumbendibus
    • 27. November 2025 um 15:10
    • #3.469
    Den Fix im Distressor muss ich unbedingt ausprobieren. Ich fand den bis dato unbrauchbar.
     WING COMPACT: DCA spill mode can be activated by pressing the SELECT button on the desired DCA
    Klingt so wie DCA Spill wie man sich ihn wünschen würde, freue ich mich auch zu testen!
    • 27. November 2025 um 15:11
    • #3.470
    Eher nach: „wieso wollen wir den Leuten eigentlich vorschreiben in welcher Reihenfolge sie die verschiedenen Dynamics nutzen sollen?“
  • Pfälzer
    • 27. November 2025 um 16:51
    • #3.471
    X-Touch scheint noch immer nicht vom Rack unterstützt zu werden. Oder ist mir da was entgangen?
    Naja, so komme ich wenigstens nicht ins Grübeln ob ich mir eins kaufen soll.
    An sonsten ein recht umfangreiches Update, könnten sich andere Hersteller mal als Vorbild nehmen.
  • MiFa1969
    • 27. November 2025 um 16:56
    • #3.472
    Auf FB stand das hier:
    Wobei mir nicht klar ist, was X-Touch mit Wing Edit zu tun hat.
    Hier noch der Link zu YT:
    • 27. November 2025 um 16:59
    • #3.473
    Ja, das ist Job des Editors. Kommt noch.
    • 28. November 2025 um 00:01
    • #3.474
    Wer mit den release notes nicht klar kommt und auf Kaugummienglisch allergisch ist, lässt sich's vom Basti erklären:
  • jimmy_punk
    • 28. November 2025 um 08:35
    • #3.475
    Bei mir macht er eine langweilige Orgel schöner, zusammen mit dem Deluxe Amp.
    Allerdings lärmt der Rotary Speaker auch wenn keiner spielt - ich werd demnächst mal das Gate hinter den Insert ziehen um das unter Kontrolle zu bringen.
    In dem Update sind einige richtig leckere Sachen dabei.
    Danke an die praxisnahen Entwickler und die Community für die Eingaben!
  • treibsand
    • 28. November 2025 um 09:03
    • #3.476
    Is das nicht eine der drei Hauptfunktionen eines Leslies? Also neben 'eine Runde Bandscheibenvorfälle für alle Beteiligten'? Die dritte hab' ich jetzt vergessen...
    Einmal editiert, zuletzt von treibsand (1. Dezember 2025 um 10:44)
  • DerAudioingenieur
    • 28. November 2025 um 09:04
    • #3.477
    Hat von euch gestern jemand schon ausgiebig damit gespielt? Überlege mir grad, ob ich das 3.1er Update für einen Job heute Abend direkt mal aufspielen soll :/
  • mellotron
    • 28. November 2025 um 09:20
    • #3.478
    Hat jemand schon die 3.1-Firmware mit der aktuellen Version von Wing Q getestet?
    • 28. November 2025 um 11:41
    • #3.479
    Stimuliert der echt auch den Motor? Kann man das im Plugin nicht deaktivieren?
    • 28. November 2025 um 11:48
    • #3.480
    Die letzten zwei betas waren so, dass ich keine Hänger gefunden habe. Trau Dich!
  1. Soundbase vs WWB
  5. Astera AX5 akku refreshen
  6. "Nutzbass"
  10. HK Audio Polar 15
  • 2 Mitglieder (davon 1 unsichtbar) und 31 Besucher
  • Elwood
Legende
  • Mitglieder
